System TCS seat altea
07 Lis 2011, 21:33
Witam
Mam problem z systemem TCS w seat altea 1,6 . Problem polega na tym ze przy niskiej temperaturze zapala sie kontrolka TCS i wlaczaja sie wentylatory. Po podlaczeniu do komputera i wykasowaniu bledu wszystko jest dobrze. Problem powraca przy niskich temperaturach.
VCDS Version: Release 10.6.4
Data version: 20110418
Monday,07,November,2011,15:10:18:10074
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72
VIN: VSSZZZ5PZ5R048450 Mileage: 94210km/58539miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 DA
Component: SIMOS71 1.6l 2VG 6467
Revision: --H03--- Serial number: SEZ7Z0D2784541
Coding: 0000071
Shop #: WSC 00000 000 00000
VCID: 61CDA1B7C1D9
3 Faults Found:
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 007 - Short to Ground - Intermittent
Freeze Frame:
RPM: 2816 /min
Mass Air / Rev.: 425.1 mg/str
Voltage: 2.060 V
Voltage: 14.48 V
RPM: 2240 /min
Mass Air / Rev.: 277.9 mg/str
Voltage: 2.060 V
Voltage: 14.48 V
17592 - Linear O2 Sensor; Common Ground Wire: Open Circuit
P1184 - 007 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
RPM: 2016 /min
Bin. Bits: 00100000
Voltage: 2.040 V
Voltage: 0.000 V
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 008 - Implausible Signal
Freeze Frame:
Temperature: 43.5°C
Temperature: 60.0°C
Temperature: 10.5°C
RPM: 2336 /min
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 06402 785 00200
VCID: 3F8947CF17ED
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
00668 - Supply Voltage Terminal 30
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 B
Component: ClimatronicPQ35 005 0202
VCID: 2F69178FC78D
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001259834
Coding: 818C0F2700041000001E00000000000000007F0B5C
VCID: 3A7F36DB0CCF
Part No: 5P0 955 119 A
Component: Wischer SE359 012 0402
Coding: 00056272
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
Component: S3 AIRBAG VW8 013 2100
Revision: 02013000 Serial number: 0033HD00AZZU
Coding: 0021299
VCID: 2C530083F69B
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0002042
VCID: 316D11F7D1B9
Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 5P0 920 822 F
Component: KOMBIINSTRUMENT VO3 1056
Coding: 0002101
Shop #: WSC 51187 142 86190
VCID: 326F1EFBD4BF
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 26001049220545
Coding: 3D3F4340078202
Shop #: WSC 73407 134 57610
VCID: 2759FFAFEF7D
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 1056
VCID: 326F1EFBD4BF
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
Part No: 1T0 959 701 A
Component: Tuersteuergeraet 09 0139
Coding: 0000016
VCID: 356525E725D1
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.12 1401
VCID: 2F69178FC78D
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 01C800407F3F8505484F011000C4
Shop #: WSC 51187 142 84711
VCID: 79FDE9D74949
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
00893 - Switch for Trunk Handle (E234)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
Part No: 1T0 959 702 A
Coding: 0000016
VCID: 366722EB38D7
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P1 035 152
Component: Radio BNO 0029
Coding: 0040400
VCID: E6C732ABA8F7
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0216
Coding: 0000016
VCID: 2F69178FC78D
Address 69: Trailer Labels: 8P0-907-383.lbl
Part No SW: 8P0 907 383 HW: 8P0 907 383
Component: ANHAENGERELEKTR H01 0010
Coding: 0000001
VCID: F6E762EBF857
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000016
VCID: 306B14F3DAB3
End ---------------------------------------------------------------------
Wymieniony zostal czujnik temperaturry ale problem powraca. Co moze byc przyczyna i gdzie szukac.
maxpol
Auto: Seat Altea
08 Lis 2011, 21:21
Hmmm, w Seacie TSC to układ zapobiegający poślizgowi kół napędowych podczas przyspieszania. Kontrolka to trójkącik z wykrzyknikiem. O tą kontrolkę ci chodziło?
09 Lis 2011, 18:21
Witam
Jest to zolta kontrolka z samochodem z dwoma zygzakami. Dzieje sie to zazwyczaj z rana jak temperatura jest okol 8 stopni lub niższa. Wiatraki wtedy chodza caly czas nawet jak tylko przekrece stacyjke.
Dzieki
maxpol
Auto: Seat Altea
04 Lut 2012, 17:28
Witaj, Udało Ci się ustalić przyczynę włączania wentylatorów i zapalania kontrolki TCS ? Mam Alteę 1.6 2004r. i objawy identyczne. Elektryk (po podłączeniu do kompa) też wskazał na walnięty czujnik temperatury (ten na bloku silnika). Napisz proszę czy ustaliłeś coś więcej ... ?
Wedd
Prawo jazdy: 11 04 1974
